Hello, friends, who can provide the test case of NASA low speed centrifugal compressor, ?
Hello Fishcuter,
Thanks for your inquiry. The NASA LSCC test case is outlined in the following papers: Hathaway M. J., Chriss R. M., Wood J. R., Strazisar A. J., 1993, "Experimental and Computational Investigation of the NASA Low-Speed Centrifugal Compressor Flow Field," ASME J. of Turbomachinery, Vol. 115, pp. 527-542 Skoch G. J., Prahst P. S., Wernet M. P., Wood J. R., Strazisar A. J., 1997, "Laser Anemometer Measurements of The Flow Field in a 4:1 Pressure Ratio Centrifugal Impeller," ASME Paper 97-GT-342 McKain T. F., Holbrook G. J., 1982, "Coordinates for a High Performance 4:1 Pressure Ratio Centrifugal Compressor," NASA Contract NAS 3-23268 There are actually several papers on this study. The three listed should give you what you need. Best regards, Allan |
thank you, Allan, I have looked those first two papers, but failed to find corresponding blade coordinates ( detailed geometry data).Anyway, I appreciate your advice.
Hi Fishcuter,
did you manage to find the coordinates for this or any other Validation model for a centrifugal compressor ? I am looking to calibrate CFX Tascflow for overall stage perfromance results only, not internal flow detail perhaps there is another model I could use ? many thanks Keith B. |
Hi, Keith:
I suggest Krain models ever published for calibration. Dai Ren |
NASA Format | Stone | CFX | 3 | August 11, 2021 02:16 |
NASA-VOF 3D code | F.F Lin | Main CFD Forum | 18 | March 8, 2015 12:44 |
some parameters in NASA-VOF 2D | nick | Main CFD Forum | 4 | July 31, 2010 10:37 |
NASA-VOF3D | Kong Kok Haw | Main CFD Forum | 3 | July 31, 2010 08:07 |
NASA-VOF2D | Morteza Marivani | Main CFD Forum | 10 | April 27, 2006 10:33 |
