Home > Forums > Software User Forums > Fidelity CFD
Kinetic Theory
Old   June 24, 2003, 13:04
Default Kinetic Theory
Tommaso
hi
In the ideal gas model using the kinetic theory for Cp and K, which are the values to insert in degrees of freedom...........
thanks in advance payment
Old   July 25, 2003, 16:53
Default Re: Kinetic Theory
BAK_FLOW
the number of translational and rotational modes are added up. For monatomic gasses this is 3 for diatomic this is 5 ie 3 translations and 2 rotations.
Cv=DOF/2*R/M Cp=(DOF+2)/2*R/M
R=universal Gas Constant 8.314[kJ/kg/K] M=mollecular Weight [kg/kmol]
So let us try this for Argon, DOF=3, M=39.94[kg/kmol]
Plug it in and get 0.527[kJ/kg/K]
compare to Reynold's and Perkins, "Engineering Thermodynamics" talbe B-6b 0.523[kJ/kg/K]
Similarly k=Cp/Cv=3/5=1.67
Try it out for nitrogen and oxygen and you will get pretty good comparison as well, ie k=1.4! So as a first approximation it works quite well for monatomic and diatomic gasses.
Regards,
BAK_FLOW
CP - KINETIC THEORY Leo FLUENT 0 October 15, 2007 11:40
Kinetic Theory Tommaso FLUENT 2 July 2, 2003 06:21
Kinetic Theory Tommaso Main CFD Forum 1 June 30, 2003 11:06
kinetic theory in Fluent Tschumperle Denis FLUENT 0 October 17, 2000 10:48
solid kinetic theory wan xiaotao Main CFD Forum 6 August 10, 1999 19:43
