Home > Forums > Software User Forums > Fidelity CFD
error
Old   April 4, 2003, 01:42
Default error
Bob Hahry
Hi, Every one,
I have problem in using Numeca60, The technique supporter in our country can't resolve the problem, who can answer me? Thanks lots.
The messages in MSDOS window when I start the IGG are list in the follows,
" CONFIG 4 CONFIG 4
CONFIG but_3d
CONFIG blockBut CONFIG 1 3 4 HDriver type : WOGL version : 2.24 planes : 24 colors : 16777216 max colors : 16777216 z buffer depth : 0 hard cutting planes: 0 hard lights : 1 hard gouraud : yes hard phong : no width : -1 cm height : -1 cm aspect ratio : -1 max width : 32 cm max height : 24 cm width resolution : 32 px/cm height resolution : 32 px/cm
'import site' failed; use -v for traceback ->STL:Tool:GroupSelector:updateGroups ->STL:Tool:GroupSelector:updateGroups HOOPS information (2,2)
There was an unexpected Hoops internal error -
You must name either a particular family member or
a particular Aheight to Mark-System-Default
regards
Bob Hahry
Old   April 4, 2003, 13:06
Default Re: error
John M.
That sounds ugly. Might want to try changing from the default graphics driver - don't know if this info is in the manual or not though.
I'm curious - what country are you in?
John
Old   April 8, 2003, 11:40
Default Re: error
Allan D. Grosvenor
Dear Bob,
We have been unable to find any record of your support request to any of our worldwide offices. Please send an E-mail directly to support@numeca.be, stating your company name and referring to this issue.
Best regards, Allan
strange fluent error: Primitive Error at Node 0 Jean-Baptiste FLUENT 8 June 14, 2022 12:11
error in COMSOL:'ERROR:6164 Duplicate Variable' bhushas COMSOL 1 May 30, 2008 05:35
"Error: Floating point error: invalid number" MI Kim FLUENT 2 January 4, 2007 11:00
Fatal error error writing to tmp No space left on device maka OpenFOAM Installation 2 April 3, 2006 09:48
Error: Floating point error: invalid number Bob FLUENT 3 June 3, 2005 19:11
