Home > Forums > Software User Forums > Fidelity CFD
Running FINE on Batch Mode
Old   March 26, 2003, 07:20
Default Running FINE on Batch Mode
Chze Yeong Tang
Can FINE be run on batch mode? If it can, may I know what are the command lines to use and where can I get more information on this?
Old   March 26, 2003, 10:20
Default Re: Running FINE on Batch Mode
Brad
Hi Tang,
Good to see you posted your request at the right place !
No idea how to run in batch mode though !
But it ought to be possible - if it is not implemented as yet then it really ought to be in the near future.
Brad.
Old   March 26, 2003, 16:41
Allan D. Grosvenor
Hello Tang,
FINE can be run in batch mode either from the command line or from the Task Manager. Please see Section 14-5 of the latest FINE manual for details.
Best regards, Allan
Running FLUENT in batch mode for Windows OS Jake Lee FLUENT 7 June 29, 2016 09:38
Running fluent with udf in batch mode zonexo Fluent UDF and Scheme Programming 2 March 10, 2012 08:50
A Loop problem when running UDF in the batch mode Jun Geng FLUENT 3 July 16, 2008 09:34
Running Job in Batch mode (EFD) Nick Sessions FloEFD, FloWorks & FloTHERM 0 April 16, 2008 17:44
problem with running UDF in batch mode James FLUENT 0 June 6, 2006 07:49
