Home > Forums > Software User Forums > Fidelity CFD
how to decide the shroud and hub line
Old   March 21, 2003, 05:49
Default how to decide the shroud and hub line
angel
hi: i want to know how to decide the shroud and hub line in numeca?
Old   March 26, 2003, 16:46
Default Re: how to decide the shroud and hub line
Allan D. Grosvenor
Hello Angel,
The choice should be based on the machinery being simulated. If the definitions of hub and shroud are not completely straight-forward (e.g., a return channel) they may be set arbitrarily.
Best regards, Allan
Old   March 27, 2003, 22:49
angel
Dear Allan thanks for your answer i input the shroud data with the format of: shroud ZR polyline
but the results display several shroud lines not one shroud line expected in the multistages-turbine,if i only figure one stage,there is not the phenomenon,should i change the input format?
Old   March 28, 2003, 16:42
Allan D. Grosvenor
I think the best thing to do at this point would be to send your AutoGrid template file to your local NUMECA support office. It may be just a formating error. You might double check the template description in the AutoGrid manual.
Best regards, Allan
Old   April 1, 2003, 03:39
NUMECA-BEIJING
Dear Angel: I think you are a user in China. NUMECA-BEIJING is now working for the supports of all users located in China. We are ready for any support requests from legal users at any time. So please do not hesitate to contact us directly with: support@numeca-beijing.com if it's possible for you.
Best regards
QI
Autogrid: discontinuity of 90 degrees in shroud Eric Joubarne Fidelity CFD 1 July 21, 2009 05:34
specifying tip clearance at the shroud Mohammad CFX 1 December 25, 2008 08:06
Turbogrid Shroud-Hub Mesh Measure Limits. Turbine Santiago Orrego. CFX 0 July 27, 2007 14:30
Hub-to-Shroud Diagramm Arianna CFX 0 April 17, 2007 12:01
how to decide viscosity for DNS Jen Main CFD Forum 3 January 22, 2003 09:13
