Home > Forums > Software User Forums > Fidelity CFD
Hexpress Rotor Stator error
Old   July 18, 2023, 06:22
Default Hexpress Rotor Stator error
Johan M
Johan M is on a distinguished road
Greetings,
I am getting no response when computing the R/S connection between a hexpress meshed voluted and Autogrid meshed impeller :
In the command shell, the process stops after searching for the Hub-to-shroud. Oddly, this issue sometimes does not arise with other meshes and the RS computation is succesfull. I have attached a notepad file comparing when the RS works and when it stalls (for similar meshes).
I will add that I did increase the resolution of the volute parasolid upon stl conversion in hexpress, which may or may not have affected the situation.
Any help would be greatly appreciated.
Kind regards,
Johan
Johan M is offline   Reply With Quote
Old   July 25, 2023, 11:35
gsgt07 is on a distinguished road
Hi Johan,
I have seen your two attached files. My suggestion is to recheck your settings, and you can also use the expert parameter to align the RS with the mesh.
GS
gsgt07 is offline   Reply With Quote
Old   August 16, 2023, 10:01
Johan M
Originally Posted by gsgt07 View Post
Hi Johan,
GS
Hi gsgt07,
Unfortunately I have still not had luck. Ive tried different domain import settings to adjust the resolution but no answer yet. Thanks for the suggestion
hexpress, impeller/volute, rotor/stator, volute
Mesh from hexpress to Starccm+ vikingcarioca Fidelity CFD 0 August 29, 2018 10:40
Hexpress export Boundary groups to OpenFOAM Hillie Fidelity CFD 1 November 27, 2017 04:32
Hexpress, move hanging nodes liyifei Fidelity CFD 6 October 12, 2015 22:08
Connection of Hexpress grid and Autogrid 5 grid Young G Fidelity CFD 3 December 1, 2014 03:53
Creating a triangular surface in Hexpress Knigge46 Mesh Generation & Pre-Processing 1 August 7, 2014 04:23
