Denys
Rep Power: 3 ![]() |
Dear colleagues,
I deal with 3D calculation of axial compressor in FineTurbo. I did steady state calculation. I have encoutered with such issue. On the stator blade, on the suction side I have zone with increased Total Pressure. It doesn't corresponds to written in books about aerodynamics of compressor. I atteched one picture and added values of parameter in different places of section of stator blade. I'd like to ask, does someone else have the same result of calculation? Perhaps, can someone explain this result or I did something incorrectly? |
Rep Power: 4 ![]() |
Hi Denys,
Please check whether your simulation is converged. Regards, GS |
Denys
Hello GS,
Thanks for your reply. My calculation was convergied. I don't remember reached level of convergience. Disbalance of mass flow between inlet and outlet equals 0.02%. And it looks like horizontal line. Regards, Denys |
Denys
To continue our conversation. I did calculation according to TUTORIAL 5. MULTISTAGE AXIAL COMPRESSOR from documentation platform. For first calculation I set up Current Grid Level = <1 1 1>, for second calculation I set up Current Grid Level = <0 0 0>. When both calculations reached convergence I opened result of calculation in CFView and created a blade to blade surface at mid-span. I could see in domain of stator blade near suction side zone with increased Total Pressure. Could someone explain this result of calculation? Regards, Denys |
compressor, fineturbo, total pressure |
Calculation result depending on the computer or version? | kdww111 | FLUENT | 0 | August 15, 2022 22:01 |
MPI Reduce operator in the parallel calculation of a nested loop | peyman.havaej | OpenFOAM Programming & Development | 0 | August 3, 2021 08:33 |
divergence of u calculation from the result | sourav0921 | OpenFOAM Running, Solving & CFD | 1 | August 1, 2019 20:22 |
Increase in CPU number during the FIRE calculation | amin_u50 | AVL FIRE | 0 | August 6, 2014 08:34 |
Calculation of initial k for RAS turbulence models | shipman | OpenFOAM | 1 | August 28, 2013 03:52 |
