Design3D : Compute Thrust and Torque for every sample in database generation |
June 29, 2023, 12:53 |
Gerard Talla
Rep Power: 3 |
Hello everyone,
I need to ask a question on how to create a Python script (using Macros) to calculate the thrust and torque of a drone's propeller for each case generated in a data generation. I already know how to do it using the "Wall" file for the basic parameter case (sample 1), but I'm unsure about how to write the script to calculate for each individual case (sample 2, sample 3, etc.). This is crucial for conducting an optimization study Here is my python script in order to compute the torque for exemple project_file = '' data_filename = '' solution_file = '3D' quantity_name = 'MACRO_TORQUE' entry_type = 'SCALAR' import os (filepath, filename) = os.path.split(data_filename) wallFile = os.path.join(filepath, '...\P_3_5000\P_3_5000.wall') with open(wallFile, 'r') as fichier: val3 =[] val4 = [] for ligne in fichier: if ligne.startswith('INVISCID PART'): val3.append(ligne[90:105]) with open(wallFile, 'r') as fichier : for ligne in fichier: if ligne.startswith('VISCOUS PART'): val4.append(ligne[90:105]) val3 = [float(j) for j in val3] val4 = [float(j) for j in val4] MNV =sum(val3) MV = sum(val4) results = MNV + MV f = open (data_filename, 'w' , 0) f.write('PARAMETER \n') s = 'NAME %s\n' %(quantity_name) f.write(s) s = 'TYPE %s\n' %(entry_type) f.write(s) s = 'VALUE %12.6f\n' %(results) f.write(s) f.close() Thanks in advance |
June 30, 2023, 06:25 |
Gerard Talla
Rep Power: 3 |
up pls I need to solve this problem quickly...
design3d, fidelity, macros, thrust, torque |
Gradients for Thrust and Torque coefficients using Finite Differences | Daaman | SU2 Shape Design | 1 | July 19, 2021 05:46 |
Calculation of thrust and torque for propeller | aeksberde | OpenFOAM Post-Processing | 2 | October 28, 2019 05:23 |
Propeller Thrust and Torque Increasing | KindaHungry | STAR-CCM+ | 1 | November 3, 2018 05:59 |
