Matthew Wang
Rep Power: 8 ![]() |
Hi all,
I'm trying to setup IGG-AutoGrid5(Turbo 181) to generate the mesh in parallel computing. Right now it only runs as a single process and uses one CPU core out of the 18, which makes it very slow for a 5 million node domain. I use a Windows 10 system with admin rights. I have used the Admin tool to setup all the MPI options, confirmed that they are running (through services.msc) and successfully registered the user as (COMPUTERNAME\UserName). I have also turned UAC off according to the documentation. Does anyone know if I need to perform any additional steps, or is AutoGrid5 able to compute in parallel at all? Thanks. |
defining the non axis hub in autogrid by external IGG file? | MaYC | Fidelity CFD | 0 | June 18, 2020 02:06 |
How to improve the accuracy of the geom in Autogrid? | swm | Fidelity CFD | 6 | March 5, 2017 01:15 |
Autogrid export CGNS mesh only with multiple base nodes??? | swm | Fidelity CFD | 5 | January 22, 2017 02:09 |
Fine/Turbo cannot open grid built by IGG, Configuration file problem? | wkjshon | Fidelity CFD | 6 | March 29, 2016 02:09 |
Negative cells in AutoGrid | funmaker | Fidelity CFD | 4 | July 17, 2012 05:34 |
