Design3D- Compute Thurst and Torque From Files |
June 22, 2023, 05:36 |
Gerard Talla
Rep Power: 3 |
Hello, I am trying to be able to calculate thrust and torque using the macro (so a pyhton code). I want to calculate F_Z and M_Z according to the data available on the "Wall" file (by summing the viscous and inviscid parts).
Can you give me a type code? Here is my wall file : FORCES AND MOMENTUM ON ACTIVE SURFACES IN MKS UNITS THE MOMENTUM IS COMPUTED FOR THE POINT WITH COORDINATES 0.0000 0.0000 0.0000 THESE COMPUTATIONS TAKE INTO ACCOUNT THE PERIODICITY OF PATCHES (PARAMETER IPERFM = 1) THE PATCH LOCATION IS GIVEN BY :BLOCK NUMBER,ISTART,IEND,JSTART,JEND,KSTART,KEND FX FY FZ MX MY MZ DOMAIN 1 PATCH LOCATION: 1 1 9 1 1 1 13 INVISCID PART 0.00000 0.444089E-15 -0.368661E-02 0.433681E-18 0.00000 -0.495484E-04 VISCOUS PART -0.317637E-21 0.00000 0.115185E-04 -0.661744E-23 0.00000 -0.654530E-07 DOMAIN 2 PATCH LOCATION: 2 1 5 1 63 37 37 INVISCID PART 0.00000 -0.520417E-16 -0.483746 0.00000 0.124683E-17 -0.378667E-01 VISCOUS PART 0.00000 0.169407E-20 0.473327E-04 0.00000 -0.158819E-21 0.278188E-05 DOMAIN 2 PATCH LOCATION: 2 5 9 1 63 37 37 INVISCID PART 0.00000 -0.520417E-16 -0.483042 0.00000 0.124683E-17 -0.378639E-01 VISCOUS PART 0.847033E-21 0.00000 0.230656E-04 0.00000 -0.105879E-21 -0.557631E-06 DOMAIN 2 PATCH LOCATION: 2 1 9 1 1 1 37 INVISCID PART 0.00000 -0.444089E-15 -0.348421 0.151788E-17 0.00000 -0.110343E-04 VISCOUS PART -0.423516E-21 0.00000 -0.771241E-05 -0.661744E-23 -0.661744E-23 0.106208E-06 DOMAIN 3 PATCH LOCATION: 3 1 25 1 1 1 73 INVISCID PART -0.266454E-14 0.00000 0.504029E-01 0.346945E-17 0.00000 0.151655E-03 VISCOUS PART 0.00000 0.118585E-19 0.183077E-03 0.00000 -0.158819E-21 0.247336E-05 DOMAIN 3 PATCH LOCATION: 3 1 1 1 63 37 73 INVISCID PART 0.00000 0.133227E-13 -401.256 0.00000 0.122125E-14 9.73432 VISCOUS PART 0.00000 0.113841E-17 0.552055E-02 0.00000 -0.249875E-19 0.146283E-02 DOMAIN 3 PATCH LOCATION: 3 1 1 1 63 1 37 INVISCID PART 0.00000 -0.131006E-13 399.818 0.00000 -0.122125E-14 -9.60761 VISCOUS PART 0.433681E-18 0.00000 -0.465081E-02 0.00000 0.271051E-19 0.217829E-03 DOMAIN 4 PATCH LOCATION: 4 1 13 1 1 1 57 INVISCID PART -0.888178E-15 -0.177636E-14 9.68961 -0.693889E-17 0.346945E-17 0.265260E-05 VISCOUS PART 0.00000 0.677626E-20 0.219303E-03 0.211758E-21 -0.211758E-21 0.126274E-05 DOMAIN 5 PATCH LOCATION: 5 1 13 1 1 1 57 INVISCID PART -0.888178E-15 0.00000 -9.31188 0.00000 -0.346945E-17 -0.147030E-04 VISCOUS PART 0.00000 0.465868E-20 0.763778E-05 -0.264698E-22 -0.264698E-22 0.153237E-05 DOMAIN 6 PATCH LOCATION: 6 1 5 1 1 1 81 INVISCID PART -0.574627E-17 0.00000 -0.557802E-05 0.00000 -0.794093E-22 0.143392E-07 VISCOUS PART 0.00000 0.190582E-20 0.143507E-04 0.00000 -0.104225E-21 0.383061E-05 DOMAIN 7 PATCH LOCATION: 7 1 9 1 1 1 33 INVISCID PART -0.536680E-17 0.00000 -0.596212E-05 0.00000 0.397047E-22 0.143901E-07 VISCOUS PART 0.00000 0.190582E-20 0.254598E-04 0.00000 -0.185288E-21 0.371034E-05 DOMAIN 10 PATCH LOCATION: 10 1 57 1 1 1 7 INVISCID PART -0.277556E-15 0.00000 11.2884 0.00000 -0.119262E-17 -0.431042E-18 VISCOUS PART 0.00000 0.677626E-20 0.400613E-04 0.529396E-22 0.00000 0.832038E-06 DOMAIN 11 PATCH LOCATION: 11 1 29 1 29 25 25 INVISCID PART -0.242861E-16 0.00000 17.2270 0.00000 -0.303577E-17 0.752272E-06 VISCOUS PART 0.00000 0.338813E-20 0.109303E-05 0.264698E-22 0.00000 0.280823E-06 DOMAIN 12 PATCH LOCATION: 12 1 57 1 5 1 1 INVISCID PART -0.867362E-17 0.00000 6.54833 0.00000 -0.195156E-17 0.141812E-07 VISCOUS PART 0.00000 0.169407E-20 0.847340E-06 0.264698E-22 0.00000 0.265007E-06 DOMAIN 15 PATCH LOCATION: 15 1 57 1 1 1 7 INVISCID PART -0.277556E-15 0.00000 -11.2907 0.00000 0.108420E-17 -0.500179E-18 VISCOUS PART -0.169407E-20 0.169407E-20 0.254132E-05 0.00000 -0.132349E-22 0.547515E-06 DOMAIN 16 PATCH LOCATION: 16 1 29 1 29 1 1 INVISCID PART -0.208167E-16 0.00000 -17.2104 0.00000 0.260209E-17 -0.227277E-06 VISCOUS PART 0.00000 0.169407E-20 -0.805830E-07 -0.132349E-22 0.00000 0.217058E-06 DOMAIN 17 PATCH LOCATION: 17 1 57 1 5 25 25 INVISCID PART -0.867362E-17 0.00000 -6.56743 0.00000 0.173472E-17 -0.576063E-08 VISCOUS PART 0.00000 0.847033E-21 -0.486823E-07 -0.661744E-23 0.00000 0.175577E-06 The only example I can find in the documentation is this: CFViewBackward(89) #(file opening) fi=open('/disk1/macros/listIn.dat','r',0) fo=open('/disk1/macros/listOut.dat','w',0) #(write header line) fo.write('Node# x_cord y_cord z_cord fieldValue\n')- #(select quantity - if the following line is commented, the active quantity is used) #QntFieldScalar('Static Pressure') #(import the type module for later use) from types import * #(skip the first line, read the file lines and extract the quantity value.) s=fi.readlines() for i in range(1,len(s)-1): #(scan line) lineList=[] for x in splitfields(s[i]): if (x!=''): lineList.append(atof(x)) #(write number and point coordinates) fo.write("%i %e %e %e"%(lineList[0], lineList[1], lineList[2], lineList[3])) #(compute value) q=ProbeXYZ(lineList[1], lineList[2], lineList[3]) #(write value - if the quantity is vectorial then q is a tuple (ordered list of elements)) if (type(q) == tuple): for j in range(0,len(q)): fo.write('%e'%(q[j])) else: fo.write('%e'%(q)) #(write end of line) fo.write('\n') #(close files) fi.close() fo.close() Last edited by Gegetalla; June 29, 2023 at 13:18. |
