Home > Forums > Software User Forums > Fidelity CFD
Problem to link CAD propeller : error main blade and hub intersection
Old   April 25, 2023, 10:13
Default Problem to link CAD propeller : error main blade and hub intersection
Gerard Talla
Gegetalla is on a distinguished road
I use AutoGrid5 and I tried to import a propeller blade modeled with SolidWorks (exported in IGES format). On the pictures, you can see the import for the hub, the shroud and the blade. However, when I want to build the mesh with the "Row Wizard" tool, I get the following error: no intersection found with Main Blade at hub
I also put the meridional view of the propeller geometry.
I tried as well as I could and I also searched for forums with similar problems but I still could not set it.....
Thanks in advance for your help!
Gegetalla is offline   Reply With Quote
Old   April 27, 2023, 22:00
Gerard Talla
up pls help
hub to shroud, numeca fine/open, propeller meshing
[TurboGrid] Including a hub region in blade passage Petercm4 ANSYS Meshing & Geometry 0 June 17, 2020 13:01
Problem with Import of CAD file aco92 Fidelity CFD 4 December 12, 2017 05:39
Ansys CFX Turbogrid, Problem with blade leading edge sitting on hub at inlet Irondome CFX 9 August 18, 2016 19:56
[TurboGrid] Wind turbine: problem with the hub radius MrDaimon ANSYS Meshing & Geometry 0 March 12, 2015 09:12
Problem in conducting CFD of analysis of wind turbine blade atulpat CFX 16 August 17, 2013 05:09
