Home > Forums > Software User Forums > Fidelity CFD
How to connect the radial diffuser grid(one channel) with volute grid in IGG
Old   February 8, 2023, 12:34
Default How to connect the radial diffuser grid(one channel) with volute grid in IGG
lihua
lihua1021 is on a distinguished road
Dear everyone,
I'm working with a centrifugal compressor, the impeller and radial diffuser grid are generated by Autogrid5(only one channel), the volute grid is generated by GridPro,I want to merge these grids with IGG, could someone tell me how to set the boundary conditions of radial diffuser outlet block patch and the inlet block patch of the volute?
thank you very much
lihua1021 is offline   Reply With Quote
[Other] radial diffuser geometry generation problem merouaneaero ANSYS Meshing & Geometry 0 March 28, 2022 19:32
On grid independent solution for pulsatile flow David FLUENT 5 March 25, 2022 04:33
Fine/Turbo cannot open grid built by IGG, Configuration file problem? wkjshon Fidelity CFD 6 March 29, 2016 03:09
Combustion Convergence problems Art Stretton Phoenics 5 April 2, 2002 06:59
Grid Independent Solution Chuck Leakeas Main CFD Forum 2 May 26, 2000 12:18
