Stanislav
Rep Power: 4 ![]() |
What is the most practiced turbulence model now?
The task is to evaluate the influence of the inlet Reynolds number on the compressor characteristic. What is the practice of applying the turbulence model and mesh parameters for stationary flow at similar task? |
Hamid Zoka
Rep Power: 18 ![]() |
Hi;
This is a very general question. According to the mentioned research topic, you should look for the most accurate one. More accurate models needs better mesh qualities and needs more works to reach a converged solution. Maybe in your case using a transition model together with turbulence model is necessary since laminar-turbulent transition is expected to happen around the airfoils. Regards |
Turbulence model and Reynolds number | neal803 | CFX | 1 | June 16, 2022 18:52 |
Turbulence model for lower Reynolds number in transient analysis | gbrajtm | Main CFD Forum | 8 | October 25, 2017 11:34 |
low reynolds number turbulence model in FLUENT | shubham jain | FLUENT | 1 | March 1, 2014 07:49 |
Turbulence model for low Reynolds number flow? | Nokadu | Main CFD Forum | 3 | May 26, 2013 11:42 |
Turbulence Model and limitation to Reynolds number | qascapri | FLUENT | 0 | January 24, 2011 10:48 |
