Who to choose the coordinates for hub and shroud curve |
Rep Power: 4 ![]() |
Hey, I want to investigate a Stator in the turbo template. How the coordinates of the hub and shroud curve needs to be so that the blade is in the channel ? I mean what is my reference ? I have attached a photo. I have the x y z coordinate system at the top and R and Z at the bottom left
problem solved
[BladeModeler] Scripting BladeGen using BGI file: LE control points on hub and shroud | jgross | ANSYS Meshing & Geometry | 7 | November 11, 2020 08:13 |
[ICEM] Forcing surface and curve to match | sherifkadry | ANSYS Meshing & Geometry | 0 | August 27, 2010 00:28 |
Actuator disk model | audrich | FLUENT | 0 | September 21, 2009 07:06 |
Where's the singularity/mesh flaw? | audrich | FLUENT | 3 | August 4, 2009 01:07 |
