Home > Forums > Software User Forums > Fidelity CFD
Omnis turbocompressor tutorial: Initial solution error
Old   February 14, 2022, 04:25
Default Omnis turbocompressor tutorial: Initial solution error
Johan M
Johan M is on a distinguished road
Hi everyone I had been doing the turbocompressor tutorial from the Omnis user guide. I had encountered a ''Cannot compute initial turbomachinery solution'' error when trying to run the simulation, seen attached.
I have checked the initial conditions against the user guide values several times but have still bee unable to spot the error. I would appreciate any assistance
regards
Johan
File Type: jpg Initial turbomachinery solution error.jpg (93.9 KB, 12 views)
Johan M is offline   Reply With Quote
Old   February 24, 2022, 14:36
Karthik S
skarthik is on a distinguished road
Dear Johan,
Can you check if the correct mesh is selected under the 'Choices' for each domain?
Are you able to run the computation by using a constant initial solution instead?
It could also be that the wrong type of boundary condition is chosen for the inlet and the outlet.
Regards,
Karthik
skarthik is offline   Reply With Quote
Old   March 9, 2022, 05:46
Johan M
Dear skarthik,
Thank you for the reply. I have checked the first suggestion you mentioned and it is indeed the correct mesh. I will try the later two suggestions out
kind regards
Johan
Maximum number of iterations exceeded chtmultiregionsimpleFoam Moncef OpenFOAM Running, Solving & CFD 28 July 13, 2020 15:26
laplacianFoam with source term Herwig OpenFOAM Running, Solving & CFD 17 November 19, 2019 14:47
chtMultiRegionSimpleFoam: maximum number of iterations excedeed. Nkl OpenFOAM Running, Solving & CFD 19 October 10, 2019 03:42
checking the system setup and Qt version vivek070176 OpenFOAM Installation 22 June 1, 2010 13:34
DecomposePar links against liblamso0 with OpenMPI jens_klostermann OpenFOAM Bugs 11 June 28, 2007 18:51
