Home > Forums > Software User Forums > Fidelity CFD
How to Increase the Sewing Tolerance in Autogrid
Old   June 22, 2020, 06:54
Default How to Increase the Sewing Tolerance in Autogrid
surya
surya25 is on a distinguished road
I'm designing a Radial Diffuser for which I created my own Hub, shroud and Blade in Catia V5 and then imported it to Autogrid Version 11.2. After defining the Leading and the Trailing edge of the Blade I ran the Row Wizard for which i got a warning saying - "Blade Surfaces Sheet Body Not Correctly Defined Try to Increase the Sewing Tolerance Manually in the Blade/Check Geometry Box
Or check the Units in the Geometry Definition Box".
surya25 is offline   Reply With Quote
Old   October 5, 2020, 02:47
Colinda
colinda1 is on a distinguished road
What are your units of the geometry and the maximum size?
Did you try increasing the tolerance in the Blade/Check geometry box?
colinda1 is offline   Reply With Quote
autogrid5, hub, numeca mesh, sewing tolerance, shroud
Foam::error::printStack(Foam::Ostream&) with simpleFoam -parallel U.Golling OpenFOAM Running, Solving & CFD 52 September 23, 2023 04:35
icoFoam Courant number growth problem tdof OpenFOAM Running, Solving & CFD 12 May 24, 2023 15:00
Biomass Combustion CFD error mankaran90 OpenFOAM Running, Solving & CFD 12 August 16, 2017 07:51
STL import is not working zordiack enGrid 9 July 1, 2014 15:49
fvSchemes, Fina residual tolerance not working Attesz OpenFOAM Running, Solving & CFD 3 March 20, 2012 04:26
