Home > Forums > Software User Forums > Fidelity CFD
NLH model
Old   June 9, 2020, 00:39
Default NLH model
luo dan
LUO DAN is on a distinguished road
hi,
I have a question whether NLH model can be used to simulate centrifugal compressor impeller (no static diffuser, i.e. no rotor stator interaction) and real gas (CO2)? The time-domain unsteady simulation can simulate centrifugal compressor impeller.
thank you
LUO DAN is offline   Reply With Quote
Old   June 9, 2020, 08:28
Hamid Zoka
Hamidzoka is on a distinguished road
As long as unsteady flow features comes form the relative rotation of adjacent rows NLH can be used. Since it assumes that unsteadiness of flow variables has a zero-averaged value which means that an unsteady behavior is repeated over the time.
In case of a single row unsteadiness has not necessarily a zero-averaged behavior in macro scales. So I think it is not applicable to use NLH in this case.
Regards
Hamidzoka is offline   Reply With Quote
Old   June 10, 2020, 10:21
luo dan
thank you for your response,
I am also confused about whether the NLH method is suitable for co2 compressor in NUMECA(for condensable gas).
when i use NLH model to conduct unsteady calculation, the case always blew up due to 'thermodynamic tables directory:c:/users/dell\……‘not found.
however, the steady calculation is ok.
thank you!
Old   June 11, 2020, 12:27
Hamid Zoka
Hi;
There may be some limitations in application of NLH method.
Have a look a Fine/Turbo users guide.
regards
[IHFOAM] The IHFOAM Thread Phicau OpenFOAM Community Contributions 392 September 8, 2023 19:10
viewFactor radiation model stuck shach934 OpenFOAM 1 May 25, 2021 12:01
interFoam wave propagation and explosion of Courant number and residuals ChiaraViola OpenFOAM Running, Solving & CFD 1 June 26, 2019 06:36
manualInjection model in sprayFoam Mentalo OpenFOAM Running, Solving & CFD 1 April 2, 2014 10:29
Problems bout CFD model of biomass gasification, Downdraft gasifier wanglong FLUENT 2 November 26, 2009 00:27
