February 21, 2020, 13:12 |
Grid point distributions in each direction
Ko Shine
Rep Power: 8 |
Is there a way to figure out grid point distributions in each direction from a generated mesh in AutoGrid, rather than total number of points? Thanks in advance! |
February 24, 2020, 05:22 |
Colinda
Rep Power: 14 |
You can see the number of points in each direction of the block in the bottom left corner if you select a block in the 3D mesh view.
February 24, 2020, 13:16 |
Ko Shine
Rep Power: 8 |
Hi Colinda,
Thanks a lot for that. Yes, I can find grid point distributions in each direction as you mentioned. Thanks for your help. |
Plot values such as turbulent kinetic energy at the first grid point from the surface | eddykendo | OpenFOAM Post-Processing | 0 | July 1, 2016 06:27 |
[snappyHexMesh] How to define to right point for locationInMesh | Mirage12 | OpenFOAM Meshing & Mesh Conversion | 7 | March 13, 2016 15:07 |
two point correlations on unstructured grid | LuckyTran | Visualization & Post-Processing | 0 | January 14, 2015 11:30 |
a reconstructPar issue | immortality | OpenFOAM Post-Processing | 8 | June 16, 2013 12:25 |
distance from the wall to the first grid point | Wenqing Zhang | CFX | 0 | August 9, 2004 11:08 |
