plotting quantities in theta direction at particular radius |
October 18, 2019, 04:19 |
Navjot joshi
I was trying to plot theta vs static pressure to see how static pressure is varying at the inlet of the blade at a particular span location ( 95% span) along the circumferential direction in CFView. I am running an unsteady case for 360 degrees simulation for an axial compressor. I had tried to cut a section at the blade leading edge and then plot the static pressure at the section, then exported the active surface quantities and, wrote a code for plotting theta vs static pressure. The plotted data is not giving any solid conclusion about how static pressure is varying due to the approximation of radius. Is there is any easy way to plot in CFView theta vs quantity at a particular radius of a section? thanking you, Navjot Joshi IIT bombay Last edited by navjot; November 4, 2019 at 07:28. |
cfview, numeca fine/open, postprocessing |
Flow Direction: normal to boundary!!! | Atit | CFX | 1 | August 2, 2015 14:42 |
Changing inflow velocity direction deteriorates lift and drag | ziggo | FLUENT | 3 | July 24, 2013 09:39 |
SST turbulence with Gamma theta and Boussinesq model | kmgraju | CFX | 2 | June 11, 2013 01:46 |
Plotting the velocity profile in normal direction along a curved surface | StSchiff | OpenFOAM | 0 | December 1, 2011 06:01 |
Plotting velocity and direction contours | bhavin1986 | Main CFD Forum | 2 | April 29, 2011 17:58 |
