June 21, 2019, 08:54 |
DES model in Fine/Turbo
Tony
Rep Power: 8 |
Hi everyone,
I'm working on the simulation of a case, I used ssT these days. But when I read the documents today, I found that Fine/Turbo has already support DES model. But there is no detail guide here, and I can't see any option here. So, how can I do DES simulation here in Fine/Turbo? Thanks all |
July 1, 2019, 08:28 |
Rep Power: 8 |
Hi Tony!
I have the same question. Have you solved it yet? |
July 16, 2019, 03:44 |
Colinda
Rep Power: 14 |
The recommended NUMECA software for DES simulations is FINE™/Open with OpenLabs™. It has a much higher level of capabilities and validation.
July 16, 2019, 07:32 |
#4 | |
Rep Power: 8 |
I don't have experiences of FINE/OPEN. Is the process of setting up a case in it just like that in FINE/TURBO? I'm performing simulations on an axial compressor. Thanks |
July 16, 2019, 08:18 |
Colinda
Rep Power: 14 |
The interface of FINE™/Open with OpenLabs™ is very similar to FINE™/Turbo. You will surely recognize the GUI as quite the same. For an axial compressor you can still use AutoGrid5™ for the meshing. This mesh can then be used for a simulation with the FINE™/Open solver. So it would be surely worth to try. |
des moedl |
SGS Model used by DES simulations | chi86 | FLUENT | 1 | March 11, 2018 11:12 |
Detached Eddy Simulation (DES) Model Urgent | ck3 | FLUENT | 4 | October 10, 2014 05:49 |
Problem with DES model | mehul | Siemens | 0 | April 12, 2006 09:01 |
Problem with DES model | mehul | Phoenics | 0 | April 12, 2006 09:00 |
Problem with DES model | mehul | Fidelity CFD | 0 | April 12, 2006 09:00 |
