Home > Forums > Software User Forums > Fidelity CFD
Split block using a surface in Igg
Old   March 28, 2019, 05:28
Post Split block using a surface in Igg
Thomas Cadario
Thomas_cad is on a distinguished road
I wanted to know if it was possible to split a block using a surface? I know it's possible to split a block with the option "Split Block", but it's not really doing what I want.
Thanks for your help,
Thomas
Thomas_cad is offline   Reply With Quote
Old   April 1, 2019, 03:01
Colinda
colinda1 is on a distinguished road
What is it exactly that you want? It is not possible to split a block of a structured grid just by any surface. How would you imagine this? It could mean e.g. for a certain i-coordinate that the surface cuts away cells in j and/ or k-direction. That would remove the principles of the structured grid.
colinda1 is offline   Reply With Quote
Old   April 1, 2019, 05:23
Thomas Cadario
Hello colinda,
The thing I want to do is to split a block in two parts in order to say to my solver that one part is rotating, and the other is not. But I need to have a "straight" cut, because that's how it is in prototype.
Thanks
Old   April 1, 2019, 05:31
Colinda
Do you mean you want to have a rotor/stator interface? In that case, you should create the blocks from the start separately on each side of the interface. There is no way to do it afterward by splitting.
Or is it just a matter of setting a boundary condition of a symmetric rotating wall? In that case, it is possible in the FINE™/Turbo or FINE™/Open GUI in the solid wall boundary conditions page to set the limits of the rotating part.
Old   April 1, 2019, 05:40
Thomas Cadario
Yes, kind of. I have a hub, and one part is rotating and the other one is not. But I've been given only the blocking. So I'll need to find another way to do it.
Thank you for your help
igg, split block
[Other] 2D adaptive Mesh Refinement baco OpenFOAM Community Contributions 80 August 14, 2022 15:18
how to split a surface in CFX POST mohammad CFX 10 February 7, 2018 03:11
Problem with entire domain comprised of split hex cells Arzed23 Main CFD Forum 1 November 8, 2016 00:01
Split a plane surface Seba22 STAR-CCM+ 3 May 16, 2014 06:09
refine mesh inside a block, water surface not smooth anymore JohnAB STAR-CCM+ 2 October 4, 2013 14:53
