Home > Forums > Software User Forums > Fidelity CFD
Full Matching mesh
Old   December 10, 2018, 06:53
Default Full Matching mesh
Allen George
allenjohngeorge is on a distinguished road
I am trying to mesh an axial turbine cascade with tip gap in AUTOGRID5. In the tip gap region the mesh is not matching fully (image attached). I would like to know whether its possible to make the mesh in this region matching without any node discontinuity. I was not able to find an option in AUTOGRID5 in expert mode to make this mesh matching. If somebody knows the solution for this, please help. Thanks
allenjohngeorge is offline   Reply With Quote
Old   December 11, 2018, 07:24
Hamid Zoka
Hamidzoka is on a distinguished road
Hi;
different topologies exist in AG5 to mesh the blade rows among which "Default" and "HOH" are suitable for axial machines.
In case of "Default" topology, boundary patches in tip gap usually remains fully matched(I actually tested it many times!). However if the mesh is of "HOH" type tip gap blocks will not necessarily be matching. Although a NMB will not impose important errors in simulations you can try "Default" topology to see its impact on NMBs.
Regards
Hamidzoka is offline   Reply With Quote
Old   December 21, 2018, 04:46
Allen George
Thank you very much for your input.
I have selected the Matching Peridoicty option for getting matching meshes at the side periodic boundaries. Now I have deselected it and when I give equal number of points in suction and pressure side, I am able to get matching mesh inside the tip gap region.
Regards,
Allen
Old   December 22, 2018, 04:06
abdul
eng.abdul is on a distinguished road
In my opinion, having matching boundaries on the side of suction and pressure surface is more important than having to match in the tip gap region. and I agree to this that non-matching mesh in the tip gap does not make a difference.
eng.abdul is offline   Reply With Quote
Full not matching boundary Luza Belmont Fidelity CFD 5 July 12, 2015 20:16
[snappyHexMesh] SnappyHexMesh no layers and no decent mesh for complex geometry pizzaspinate OpenFOAM Meshing & Mesh Conversion 1 February 25, 2015 08:05
[ICEM] Generating Mesh for STL Car in Windtunnel Simulation tommymoose ANSYS Meshing & Geometry 48 April 15, 2013 05:24
[Gmsh] 2D Mesh Generation Tutorial for GMSH aeroslacker OpenFOAM Meshing & Mesh Conversion 12 January 19, 2012 04:52
