the problem to generate grids for turbine in Numeca |
Rep Power: 0 ![]() |
hi,everyone,
when i use Numeca>Autogrid5 to generate grids for turbine, i meet the problem that "main blade: trailing edge does not intersect shroud", i find There is a gap between blade and shroud in fact, so, how can I extend the length of the blade to intersect shroud in Autogrid5 ?any advise? thank you very much! |
Hamid Zoka
Rep Power: 18 ![]() |
hi;
It has a simple solution! on the rows list on left side of AG5 right click on "main blade" then select "geometry" and then "expand". By adjusting expansion factor you can let the blade intersect both shroud and hub curves which is necessary for meshing in AG5. Note that depending on your software version the way you can get the "expand" option may be a little different! |
autogrid5, grids, numeca |
Connectivity problem with grids created using gmsh | shank19 | SU2 | 3 | May 10, 2017 08:54 |
Heat Transfert, mixing problem | Wazdq | CFX | 8 | November 7, 2016 05:44 |
problem related to staggered grids | zhu | Main CFD Forum | 10 | October 27, 2001 22:30 |
extremely simple problem... can you solve it properly? | Mikhail | Main CFD Forum | 40 | September 9, 1999 09:11 |
unstructured vs. structured grids | Frank Muldoon | Main CFD Forum | 1 | January 5, 1999 10:09 |
