Home > Forums > Software User Forums > Fidelity CFD
Limiting Streamlines
Old   October 3, 2018, 23:40
Default Limiting Streamlines
Vishwas Verma
vishwasvemra is on a distinguished road
Hello all,
Its a bit silly question, but I am having difficulty in plotting limiting streamlines on solid surfaces in CFView. Actually I am unable to find this option. Also I am unable to plot streamline starting from a surface in a uniform way, by putting seeds on it. I am able to generate streamlines from a section(using Representation>streamline>section), but I would like to generate uniform streamlines from say inlet plane.
Can anyone please help me.
Thank you!!
Kind Regards,
Vishwas
vishwasvemra is offline   Reply With Quote
Old   October 9, 2018, 06:37
Hamid Zoka
Hamidzoka is on a distinguished road
Hi;
Regarding the limiting streamlines, prior to run you should select viscous stress icon from "solid data" tab of computed variables from "Output" menu in FINE/TURBO solver. then in Cfview all you need is to plot vector lines of viscous stress. you can manage its appearance and set the number of streamlines.
e.g. 10 streamlines along the blade height.
regards
Hamidzoka is offline   Reply With Quote
limiting streamlines... srikanth Main CFD Forum 5 September 5, 2018 08:22
Limiting Streamlines and CFD-Post m5edr FLUENT 0 February 14, 2015 06:49
Interpreting streamlines of a rotating fan. danbence Visualization & Post-Processing 1 April 8, 2014 11:13
[General] Limiting streamlines using surfaceLIC plugin Tarak ParaView 16 March 3, 2014 12:00
visualisation of limiting streamlines babi CFX 0 March 8, 2002 04:07
