Home > Forums > Software User Forums > Fidelity CFD
IGG mesh
Old   August 17, 2018, 08:57
Default IGG mesh
Sunag R A
rasunag1991 is on a distinguished road
Dear Numeca,
I am currently working on 6:1 3D prolate mesh in IGG software. With respect to this, I have created a semi mesh which I will export in Hexpress and do the complete mesh by rotation. Later, I will run the simulation in FINE/MARINE.
Now, my problem is I have created a mesh using face and converted to block by "Block by face rotation" in IGG. In doing so, there is one boundary conditon which is giving me a problem. This boundary condition is taking a line as face. I have given this boundary condition as "Symmetry/mirror" and ran in Hexpress. The mesh seems fine. But, when I load in FINE/MARINE, at the pre-processing stage, it either shows mismatch or it runs showing that "There is a edge with zero length" . I have attached the pictures related to it.
Hope you have understood the question and please help me resolve this.
rasunag1991 is offline   Reply With Quote
Old   August 20, 2018, 03:19
Colinda
colinda1 is on a distinguished road
This way of creating a mesh is invalid as you understand from the message: it creates a face collapsed into a line.
It would be better to create a butterfly mesh in this geometry in IGG. This will avoid the need to put a singular line and give a good mesh quality.
colinda1 is offline   Reply With Quote
Old   August 21, 2018, 05:57
Sunag R A
Dear Colinda,
I tried to use butterfly mesh for the same geometry. But since the butterfly mesh takes the shape of the parent block, it does not affect anything and also I had created the block using "block by face rotation".
So, I tried to change the computational domin to rectangular. But for rectangular domain, I cannot cover the entire body domain which is shown in picture. I cannot add the vertex also as it will merge the lines. I am just trying to create the half domain so that I can rotate in Hexpress.
I have attached photo the rectangular computational domain and the photo of body domain and highlighted where the line is missing.
hexpress mesh, igg, numeca fine marine
sliding mesh problem in CFX Saima CFX 46 September 11, 2021 08:38
decomposePar problem: Cell 0contains face labels out of range vaina74 OpenFOAM Pre-Processing 37 July 20, 2020 06:38
[ICEM] surface mesh merging problem everest ANSYS Meshing & Geometry 44 April 14, 2016 07:41
[ICEM] Problem making structured mesh on a surface froztbear ANSYS Meshing & Geometry 4 November 10, 2011 09:52
[ICEM] Problem making structural mesh on a surface froztbear ANSYS Meshing & Geometry 1 November 10, 2011 09:52
