Home > Forums > Software User Forums > Fidelity CFD
ZR Effect in Autogrid5 as a script
Old   July 30, 2018, 10:10
Default ZR Effect in Autogrid5 as a script
PLD
parthiv1991 is on a distinguished road
Hello Users,
I am trying to implement a small cavity in a turbomachinery application in Numeca Autogrid. I have successfully implemented the cavity as a ZR Effect manually using the GUI. But I want to implement it in a python script file.
I have tried it using the scripts generated when doing it manually and simply copied and pasted it into an existing python script. Everything works fine except that the script does not generate any zr effect and it does not execute the zr effect part. Can anyone please help me with this?
Here's the script based on the advanced tutorial 10.
# the previous lines are same as in the tutorial, the next lines are for thr Rotor Row(2) generation
# control the grid points
row(2).blade(1).set_b2b_default_topology_grid_point_number_streamwise_inlet(9)
row(2).blade(1).set_b2b_default_topology_grid_point_number_azimutal_inlet_down(13)
row(2).blade(1).set_b2b_default_topology_grid_point_number_streamwise_blade_upper_side(61)
# switch on and control the optimization
row(2).set_row_optimization_steps(150)
# Cavity Creation
row(2).select()
row(2).a5_new_ZR_effect()
zr_techno_effect_start_edit_mode()
parametric_polyline_3_solid_rotating = new_parametric_polyline("parametric_polyline_3_solid_rotating")
generation_error_message()
parametric_polyline_3_solid_rotating.insert_point(1,CurvePointNorm(Curve("ni_original_hub#0"),0.63208298968232))
parametric_polyline_3_solid_rotating.move_point(1,CurvePointNorm(Curve("ni_original_hub#0"),0.63208298968232))
parametric_polyline_3_solid_rotating.insert_point(2,Point(0.115389087626934,0.245,0))
parametric_polyline_3_solid_rotating.move_point(2,Point(0.115379087626934,0.243274033069611,0))
parametric_polyline_3_solid_rotating.insert_point(3,Point(0.115389087626934,0.243274033069611,0))
parametric_polyline_3_solid_rotating.remove_point(3)
parametric_polyline_4_solid = new_parametric_polyline("parametric_polyline_4_solid")
parametric_polyline_4_solid.insert_point(1,CurvePointNorm(parametric_polyline_3_solid_rotating,1))
parametric_polyline_4_solid.move_point(1,CurvePointNorm(parametric_polyline_3_solid_rotating,1))
parametric_polyline_4_solid.insert_point(2,Point(0.115389087626934,0.243274033069611,0))
parametric_polyline_4_solid.move_point(2,Point(0.116006687283516,0.243274033069611,0))
parametric_polyline_4_solid.insert_point(3,Point(0.116016687283516,0.243274033069611,0))
parametric_polyline_4_solid.move_point(3,CurvePointNorm(Curve("ni_original_hub#0"),0.634811683841372))
parametric_polyline_4_solid.insert_point(4,Point(0.116016687283516,0.245,0))
parametric_polyline_4_solid.remove_point(4)
zr_techno_effect_set_boundary_point(0,CurvePointNorm(parametric_polyline_4_solid,0.156145948858037))
zr_techno_effect_reset_boundary_point(1)
zr_techno_effect_delete_blocks()
new_block_face(Point(0.115692887455229,0.243587832724464,0),CurvePointNorm(parametric_polyline_4_solid,0.133116841394939),CurvePointNorm(parametric_polyline_4_solid,0),CurvePointNorm(parametric_polyline_3_solid_rotating,0.817971014489298),0,0,3,0)
new_block_face(Point(0.115692887455229,0.243587832724464,0),CurvePointNorm(parametric_polyline_4_solid,0.40014829882754),CurvePointNorm(parametric_polyline_4_solid,0.266658976255374),CurvePointNorm(parametric_polyline_4_solid,0.133116841399667),0,0,3,0)
new_block_face(CurvePointNorm(Curve("ni_original_hub#0"),0.633445160769692),Point(0.115692887455229,0.243587832724464,0),CurvePointNorm(parametric_polyline_4_solid,0.400148298818682),CurvePointNorm(Curve("ni_original_hub#0"),0.634811683841373),0,0,3,0)
new_block_face(CurvePointNorm(Curve("ni_original_hub#0"),0.633445160769692),Point(0.115692887455229,0.243587832724464,0),CurvePointNorm(parametric_polyline_3_solid_rotating,0.817971014489298),CurvePointNorm(Curve("ni_original_hub#0"),0.63208298968232),0,0,3,0)
zr_techno_effect_compute_default_mesh()
zr_techno_effect_stop_edit_mode()
# generate B2B
unselect_all()
row(2).select()
a5_generate_b2b()
# the next lines are also same as in the tutorial script ........
parthiv1991 is offline   Reply With Quote
autogrid5, zr effect
[Workbench] Run ICEM Script in Workbench Script MIZOR ANSYS Meshing & Geometry 9 April 4, 2018 08:45
Shell script to handle Segmentation faults arising from execFlowFunctionObjects pruthvi1991 OpenFOAM Post-Processing 0 February 22, 2015 15:20
[ICEM] Problem with ICEM Script Meshing asal ANSYS Meshing & Geometry 2 March 23, 2013 20:11
CentFOAM Python Script Installation: Error socon009 OpenFOAM Installation 2 May 26, 2012 10:36
Can 'shock waves' occur in viscous fluid flows? diaw Main CFD Forum 104 February 16, 2006 06:44
