May 16, 2018, 01:47 |
Massflow imbalance
Hamid Zoka
Rep Power: 19 |
Hi everyone;
Applying endwall fillets in multi-row simulations increases massflow imbalance. (up to 0.7% in some cases!). Neither fine meshes nor increased mesh concentrations around the fillets does not solve the problem. Is there any specific guideline to lower the error level? Thanks |
May 16, 2018, 04:27 |
Holger Dietrich
Rep Power: 15 |
You may check the .mf file (with expert parameter IWRIT=1 activated) to check the flux losses over the interfaces. Shock waves near the interface can also result in mass flow imbalances. Might this be the case in your application? I am not sure if it is directly related to the fillets.
May 16, 2018, 05:42 |
Hamid Zoka
Rep Power: 19 |
Thanks for the prompt response!
Actually the case has no shocks at interfaces. on the other hand the strange issue is that the imbalance is quite lower in similar case with no endwall fillets. |
Out File does not show Imbalance in % | Mmaragann | CFX | 5 | January 20, 2017 11:20 |
Problem with massflow BC at inlet | MrNavierStokes | CFX | 3 | November 7, 2016 03:55 |
Domain Imbalance | HMR | CFX | 5 | October 10, 2016 06:57 |
domain imbalance for enrgy equation | happy | CFX | 14 | September 6, 2012 02:54 |
MassFlow Function? Absolute MassFlow? Failure in Caclulation | eRzBeNgEl | CFX | 0 | May 5, 2011 10:46 |
