Home > Forums > Software User Forums > Fidelity CFD
CFView Error in Opening solution File
Old   May 8, 2018, 14:13
Default CFView Error in Opening solution File
Vishwas Verma
vishwasvemra is on a distinguished road
Dear all,
I am getting IO error(please see attached) while trying to open solution file in CFView. I have ran the simulation on cluster in fine turbo 12.1, and transferred the solution file on local desktop. I am not exactly sure, why does CFView accepts some files and for other it shows this error.
Could anyone please help.
Kind regards
Vishwas
vishwasvemra is offline   Reply With Quote
Old   May 11, 2018, 00:56
Vishwas Verma
I am still stuck at this point. Has anyone not encountered this issue earlier?
I don't know why files are opening on server machine(post-processing on server is dead slow) but not on local desktop. Does anyone please can help to solve this issue ?
thanks!!
Regards
Vishwas
Old   May 14, 2018, 03:47
Colinda
colinda1 is on a distinguished road
Which solution files did you transfer to your local machine? Did you well transfer the entire computation folder or only a part of it?
Did the simulation run sufficiently long to save a full solution that can be used for post processing or did you select to save such file 'at end only' and the simulation was stopped before the end?
Best regards,
Colinda
colinda1 is offline   Reply With Quote
Old   May 17, 2018, 04:10
Vishwas Verma
Dear Colinda,
Thanks for replying. I had transferred the complete directory of solution folder (files can be seen in attached snapshot). Also the solution is completely converged and stopped by itself, after satisfying the convergence criterion.
Many Thanks!!
Kind Regards
Vishwas
Old   May 26, 2018, 23:52
Default Error CFview
Maful suranto
Maful is on a distinguished road
If io error at open CFview fine marine, in under picture... Why?.please help me..
Maful is offline   Reply With Quote
Old   July 7, 2018, 03:52
Vishwas Verma
found the solution for this problem. Actually the case was run on linux based OS, the local machine has windows OS. In linux distro, there is no issue in opening run files.
Not sure why does this happen with only few cases.
Regards
vishwas
OpenFoam "Permission denied" and "command not found" problems. iyidaniel@yahoo.co.uk OpenFOAM Running, Solving & CFD 11 January 2, 2018 07:47
[swak4Foam] Error bulding swak4Foam sfigato OpenFOAM Community Contributions 18 August 22, 2013 13:41
"parabolicVelocity" in OpenFoam 2.1.0 ? sawyer86 OpenFOAM Running, Solving & CFD 21 February 7, 2012 12:44
pisoFoam compiling error with OF 1.7.1 on MAC OSX Greg Givogue OpenFOAM Programming & Development 3 March 4, 2011 18:18
DecomposePar links against liblamso0 with OpenMPI jens_klostermann OpenFOAM Bugs 11 June 28, 2007 18:51
