Home > Forums > Software User Forums > Fidelity CFD
Solver crashed
Old   September 25, 2017, 13:25
Default Solver crashed
dha_90 is on a distinguished road
Hello together,
the Numeca solver of my computation (flow of a rotor blade) always stops and I get the message:
! This type of profile x is not yet implemented in the initial solution for turbomachinery.
What does it mean and can anybody help? :/
Greetings
David
dha_90 is offline   Reply With Quote
Old   September 25, 2017, 17:49
DarylMusashi's Avatar
Holger Dietrich
DarylMusashi is on a distinguished road
Dear David,
at a first glance there seems to be an incompatibility between your boundary conditions and the turbomachinery initial solution.
What you can do to figure out the problem:
1. Do you use the latest version of FINE/Turbo (11.2)? Maybe this incompatibility is already fixed in a recent version.
2. Initial Solution tab: You can try to initialize with "constant values" instead of "for turbomachinery". Does the error persists?
If this fixes your problem I would recommend to perform a 111-computation (Numerical Model Tab: Current grid level 1 1 1) with constant values until full convergence. In a second step you duplicate this computation and switch to Numerical Model -> Current grid level 0 0 0. Please make sure to increase the maximum number of grid level (below) from 2 to 3. Finally, in the Initial Solution tab you set your converged 111 (medium grid size) computation as the initial file for the 000 (finest grid) computation.
3. I assume you use profile data instead of constant values in the "Boundary Conditions" tab. If it is an option for you (even for figuring out the reason for this error) you can try to switch all values with profile data to constant values. Does the error persists when you keep the initialization "for turbomachinery"?
Kind regards,
Holger
DarylMusashi is offline   Reply With Quote
fluent divergence for no reason sufjanst FLUENT 2 March 23, 2016 17:08
thobois class engineTopoChangerMesh error Peter_600 OpenFOAM 4 August 2, 2014 10:52
Divergence problem Smaras FLUENT 13 February 21, 2013 06:03
3d vof Smaras FLUENT 2 February 19, 2013 07:58
why the solver reject it? Anyone with experience? bearcat CFX 6 April 28, 2008 15:08
