Problem with linking a TGrid .msh mesh into fine open61 |
March 29, 2017, 08:48 |
Anne
Hi all
I have a mesh that was converted from OpenFOAM to a .msh file. The mesh is a flat plate with 8000 cells. I have been trying to link the mesh as a TGrid file in fine open61 but the mesh information area shows that there are zero vertices in my mesh. I tried with a different mesh but get the same thing. Has anyone tried to link a TGrid mesh in fine open and run a simulation successfully? Thanks |
March 30, 2017, 02:54 |
Holger Dietrich
Rep Power: 15 |
Dear Anne,
may I ask how you transformed the openFOAM mesh to .msh format? Kind regards, Holger |
March 30, 2017, 03:07 |
Anne
April 2, 2017, 15:42 |
Holger Dietrich
Rep Power: 15 |
Dear Anne,
I tested it on the openFOAM motorbike tutorial (incompressible/simplefoam) and can confirm this behavior. I converted the openFOAM mesh with FoamMeshToFluent and linked this .msh file in FINE/Open. After this several HEXPRESS specific mesh files are generated (.bcs, ,.dom, .fnmb, .igg ). Unfortunately the .dom or .igg file cannot be opened in HEXPRESS for further inspection or manipulation. When starting a computation in FINE/Open the solver crashes before the first iteration. A *.fnmbh file wasn't found. From another project I copied such a *.fnmbh file into the mesh folder, which was empty in my opinion (except a header). That didn't help much. It still crashes. I think you chose the conversion to .msh format because it seemed to be compatible with FINE/Open? From my experience it isn't possible to run openFOAM meshes in FINE/Open. |
.msh, fine/open, tgrid mesh |
[Gmsh] gmshToFoam problem: not the same mesh in Gmsh vs. paraview | zhernadi | OpenFOAM Meshing & Mesh Conversion | 8 | July 7, 2011 02:28 |
fluent add additional zones for the mesh file | SSL | FLUENT | 2 | January 26, 2008 11:55 |
OpenFOAM with Cygwin | kitchener | OpenFOAM Installation | 6 | April 24, 2006 23:09 |
How to control Minximum mesh space? | hung | FLUENT | 7 | April 18, 2005 09:38 |
unstructured vs. structured grids | Frank Muldoon | Main CFD Forum | 1 | January 5, 1999 10:09 |
