November 1, 2016, 17:32 |
Hubless Propeller in AutoGrid
Syamsi Firdaus
I wanna ask something, as i know, AutoGrid need 3 important definition : Shroud, Hub and Blade i've project to analyze hubless propeller. its possible to analyzing in Fine Turbo with meshing in AutoGrid? When i try to link Geometry, I cant link blade surface to blade. Hope all of you can help me Thank you Attached file : Capture imported Geometry in Import CAD Window syamsi11@mhs.ne.its.ac.id |
November 7, 2016, 02:30 |
Colinda
Rep Power: 14 |
The blade is physically connected to the shroud then? Sure it is possible to analyze in AutoGrid. You just need to define a virtual hub and add a block for the center part e.g. in a 3D effect.
November 18, 2016, 08:27 |
#3 | |
Syamsi Firdaus
Thanks for your response. i still confuse about that virtual hub and block for the center. may you explain more specific to me? |
November 21, 2016, 10:07 |
Colinda
Rep Power: 14 |
In your CAD or in the CAD import window of AutoGrid5 you may define a virtual hub. What I mean by virtual that you will mesh it as if it is a wall but then you can add a 3D effect in your AutoGrid5 project that inserts a (butterfly)block in the part from 0 radius up to the hub and that is connected with a full non-matching connection for example.
So the virtual hub is not a real wall but a connection to the inner fluid region. Alternative to a 3D effect in AutoGrid5, the block can be added in IGG. |
autogrid5, numeca |
Propeller calculation | toil | CFX | 15 | May 22, 2017 04:06 |
motion constraints for a boat moved by propeller | simon-2 | OpenFOAM Running, Solving & CFD | 0 | September 14, 2015 16:28 |
Propeller mesh problem for Autogrid 5 | Johnson Shi | Fidelity CFD | 2 | August 9, 2014 03:56 |
(AutoGRID 5) Problem in Geometry definition of propeller | venkat_aero2007 | Fidelity CFD | 14 | July 31, 2012 14:05 |
Modelling a propeller | tomg | STAR-CCM+ | 4 | April 28, 2011 17:22 |
