Home > Forums > Software User Forums > Fidelity CFD
Always gives the wrong location of edges through importing geomTurbo.
Old   March 31, 2016, 08:15
Unhappy Always gives the wrong location of edges through importing geomTurbo.
Nate Lau
SNeCu is on a distinguished road
The configuration is right but the location of leading edge and trailing edge is opposite... causing stream-wise error.
Are there anything wrong with my file?
http://yun.baidu.com/share/link?shar...&uk=3507042094
SNeCu is offline   Reply With Quote
Old   March 31, 2016, 16:52
DarylMusashi's Avatar
Holger Dietrich
DarylMusashi is on a distinguished road
Please do the following steps to repair your orientation:
1. Open your project with the wrong orientated blade, select "row 1"
2. Click on the left panel under Geometry Definition "Init from an external CAD file" (Picture 1)
3. "File" "Open": Import your wrong orientated geomTurbo file. Make sure "row 1" in the row definition panel on the left side is selected during the following procedure.
4. (optional) Click alt-s do make the solid visible (Picture 2)
5. The left edge is your leading edge. Go to "Select" "Curves". Select your leading edge (its marked yellow then). Right click. "Link to leading edge". Ignore the error.
6. The right edge is your trailing edge. Go to "Select "Curves". Select your trailing edge (its marked yellow then). Right click. "Link to trailing edge".
7. Click somewhere else to unmark the trailing edge. Maybe click "Select" "Curves" again, now you can draw a bounding box to select all curves of the blade. After all curves (except leading and trailing edge) are highlighted yellow: Right click, "link to blade"
8. Go to "Select" "Surface list". Mark both surfaces. Click Apply. Right click anywhere in the CAD-window and click "link to blade".
9. Close the CAD-window.
10. Generate a high quality blade mesh within seconds with the row wizard. :-)
DarylMusashi is offline   Reply With Quote
autogrid5, geomturbo, numeca
problem during mpi in server: expected Scalar, found on line 0 the word 'nan' muth OpenFOAM Running, Solving & CFD 3 August 27, 2018 05:18
udf error srihari FLUENT 1 October 31, 2016 15:18
Wrong boundary layer with movingWallVelocity fernexda OpenFOAM Post-Processing 2 September 5, 2015 20:27
meshing of a compound volume in GMSH shawn3531 OpenFOAM 4 March 12, 2015 11:45
[snappyHexMesh] problems using snappyHexMesh 2.1.0 on a supercomputer Sunxing OpenFOAM Meshing & Mesh Conversion 9 September 20, 2014 10:30
