March 28, 2016, 09:14 |
Mesh optimization in Autogrid5
陈涛
Hi all
Those days, I use AutoGrid5 8.7-2 to create a mesh of a divergent axial turbine with one cascade. When I presented the mesh to my professor last week, he told me that quality of mesh near the end wall didn’t meet his demands, especially in orthogonality. He suggested, if possible, that the grid line in spanwise direction should be almost vertical with end wall(see figure). I’ve tried to optimize mesh for several times, but I found it’s difficult to control the spanwise grid lines to be vertical with the end wall. Would you tell me whether I can optimize the mesh or how to get it. Thanks ! |
June 13, 2016, 05:10 |
Colinda
Rep Power: 14 |
The shape of the grid lines in spanwise direction is imposed by the z-constant lines. You could modify the shape of these lines in the meridional view.
autogrid5, end wall, mesh, orthogonality, vertical |
[snappyHexMesh] Add Mesh Layers doesnt work on the whole surface | Kryo | OpenFOAM Meshing & Mesh Conversion | 13 | February 17, 2022 08:34 |
[ICEM] surface mesh merging problem | everest | ANSYS Meshing & Geometry | 44 | April 14, 2016 07:41 |
[ANSYS Meshing] Combine solid mesh generated in workbench mesh and fluid mesh in fluent meshing ? | RPjack | ANSYS Meshing & Geometry | 2 | August 27, 2015 10:33 |
[ICEM] Orthogonality/Skew issues in 3D unstructured mesh | eddyy19g | ANSYS Meshing & Geometry | 3 | February 13, 2014 10:36 |
[snappyHexMesh] snappyHexMesh won't work - zeros everywhere! | sc298 | OpenFOAM Meshing & Mesh Conversion | 2 | March 27, 2011 22:11 |
