Home > Forums > Software User Forums > Fidelity CFD
average results in .MF file
Old   January 11, 2016, 04:45
Default average results in .MF file
Piotr
piotr1987 is on a distinguished road
Currently i am anylizing centrifugal compressor stage (impeller+return channel). In .MF file there are global average results at inlet of impeller, outlet of return channel and also at rotor/stator interface. I wonder if it's possible to get aditional average results of any selected area (f.e at impeller outlet or somewhere in diffuser) ?
piotr1987 is offline   Reply With Quote
Old   January 11, 2016, 08:02
DarylMusashi's Avatar
Holger Dietrich
DarylMusashi is on a distinguished road
Dear Piotr,
I think this is not possible. But you can obtain the needed information in CFView. Therefore I recommend to generate an IJK Surface (CTRL-z). Now you can specify the direction of the surface and on the right hand side of the window the domain, where the surface should be generated. Click “Apply” for preview and “Save” to generate the surface.
Now you find this surface in the upper left corner of the GUI, it should be named like “D3.K=0.333333”.
You can select the quantity you are interested in now, then go to “Representations” -> “Integrals”. There click “Scalar Average”. Now the scalar average of the selected flow variable is printed in the lower right corner of the GUI. If you are interested in the mass flow just click on the mass flow button in the Integrals section.
Best regards
Holger
DarylMusashi is offline   Reply With Quote
Old   January 11, 2016, 08:17
Piotr
Thank you !
[foam-extend.org] problem when installing foam-extend-1.6 Thomas pan OpenFOAM Installation 7 September 9, 2015 22:53
[OpenFOAM] Annoying issue of automatic "Rescale to Data Range " with paraFoam/paraview 3.12 keepfit ParaView 60 September 18, 2013 04:23
2.0.x on Mac OSX niklas OpenFOAM Installation 74 March 28, 2012 17:46
"parabolicVelocity" in OpenFoam 2.1.0 ? sawyer86 OpenFOAM Running, Solving & CFD 21 February 7, 2012 12:44
DxFoam reader update hjasak OpenFOAM Post-Processing 69 April 24, 2008 02:24
