June 26, 2015, 19:06 |
WAKE cfview
Francesco
Rep Power: 12 |
Dear all,
I need to plot on the propeller plane the axial velocity. Basically I created the new plane and I created the new quantities Relative Velocity_X. The trouble is that I want to reduce the visualization only in the area around the propeller and define the axis in the origin of the propeller. Some tips about this? Do you have experience on this matter. Thanks in Advance |
June 30, 2015, 13:06 |
Erwann
Rep Power: 11 |
Dear Francesco,
Which version of CFView are you using? Are your results from FINE/Marine or FINE/Open? In case of marine application, I guess the section of the documentation called "Wake flow tool" (Marine Specific Features from CFView user guide) might be useful in your case. The plugin represents the velocities (including the axial velocity) in a circular cut around the propeller. I hope this can help Last edited by tdrerwann; July 2, 2015 at 07:39. |
Wake length behind a circular cylinder | Corleone84 | STAR-CCM+ | 6 | December 31, 2015 02:10 |
[ICEM] wake modeling (internal wall, patch dependent) | robert86 | ANSYS Meshing & Geometry | 1 | April 27, 2015 12:44 |
having some issues in Wake Stability using UVLM for propellers | jackgeo | Main CFD Forum | 1 | November 26, 2014 06:05 |
Wake behind a two crossing cylinders | Heini | FLUENT | 0 | May 8, 2013 17:54 |
Cylinder Wake calculation | Adam Chapman | Main CFD Forum | 1 | January 30, 2007 13:54 |
