Home > Forums > Software User Forums > Fidelity CFD
How to adjust toggle vertice of 3D block in IGG other than manual adjustment?
Old   June 11, 2015, 11:52
Default How to adjust toggle vertice of 3D block in IGG other than manual adjustment?
航之梦
hangyufenfei is on a distinguished road
hello guys, I want to mesh a 3D geometry in IGG software, and I created 3D block according to the topology of the geometry. But some of the toggle vertices of 3D block were not positioned suitablely, and I want to adjust their positions. Are there any way other than manual adjustment?
hangyufenfei is offline   Reply With Quote
Old   June 19, 2015, 04:55
Erwann
tdrerwann is on a distinguished road
To adjust position of toggle vertices in IGG you can use a script file. You may find more details in the documentation of IGG.
The easiest way in your case would be to record your manual adjustment once (from the interface, File/Scripts/Record) and then have a look at the script file you have created to better understand the structure of it (details of the commands are given in the documentation).
Finally, you will be able to modify the script at your convenience and execute it to avoid extra manual adjustment.
I hope this might help.
Regards,
Erwann
tdrerwann is offline   Reply With Quote
[blockMesh] Mixer mesh - negative volume problem jadtwo OpenFOAM Meshing & Mesh Conversion 2 November 6, 2014 17:37
foamLog not solving for Ux, Uy, Uz aerospain OpenFOAM Post-Processing 5 April 18, 2012 11:01
[Commercial meshers] Icem Mesh to Foam jphandrigan OpenFOAM Meshing & Mesh Conversion 4 March 9, 2010 03:58
