May 26, 2015, 05:14 |
AUTOGRID: merge 2 mesh files
Seb
im using autogrid for mesh generation of a multi-stage axial compressor. I want to mesh the rows seperately and merge the cgns files afterwards. Is there a feature in autogrid/igg which supports this? |
June 9, 2015, 01:21 |
Hamid Zoka
Rep Power: 19 |
hi,
why do you need to have the rows meshed separately? do you want to use another solver? in case you use other solvers you can import cgns of all rows together. |
June 15, 2015, 04:04 |
Colinda
Rep Power: 14 |
If you have 2 AutoGrid5 meshes, you have two mesh projects saved as *.igg.
In IGG you can open one of the two project files *.igg and then use File/Import IGG Project and select your second mesh project. In this way you can combine them, adjust the boundary conditions (rotor/stator interface) and save it as one project. But I join the previous post in wondering why you would wish to do so though as you can save all in one AutoGrid5 project right-away. |
Star CCM Overset Mesh Error (Rotating Turbine) | thezack | Siemens | 7 | October 12, 2016 12:14 |
[snappyHexMesh] SnappyHexMesh for internal Flow | vishwa | OpenFOAM Meshing & Mesh Conversion | 24 | June 27, 2016 09:54 |
[ICEM] Merge created block resulting in not connected mesh | imamwfgf | ANSYS Meshing & Geometry | 2 | October 20, 2013 07:22 |
about merge mesh | lian | Main CFD Forum | 3 | February 29, 2008 11:47 |
Icemcfd 11: Loss of mesh from surface mesh option? | Joe | CFX | 2 | March 26, 2007 19:10 |
