May 10, 2015, 12:25 |
TE Max Angle in AutoGrid?
Brian
Rep Power: 11 |
I'm trying to mesh a compressor rotor stage in AutoGrid. The mesh quality looks good, but I am required to run it through an in-house program to look at the grid metrics. I have been having an issue where my "Max Trailing Edge Angle" is too high - I can't get it below 9.4 degrees but it is supposed to be under 8 degrees.
As a suggestion to fix this issue the program says: "Increase nte or reduce te_angle or combination of these". I'm guessing this has something to do with the skewness around the TE but no matter what I do to the grid there it doesn't improve much. There's no additional documentation - does anyone know what this metric is referring to? |
y+ and u+ values with low-Re RANS turbulence models: utility + testcase | florian_krause | OpenFOAM | 114 | August 23, 2023 06:37 |
Near wall treatment in k-omega SST | Arnoldinho | OpenFOAM Running, Solving & CFD | 38 | March 8, 2017 14:48 |
[Netgen] Import netgen mesh to OpenFOAM | hsieh | OpenFOAM Meshing & Mesh Conversion | 32 | September 13, 2011 06:50 |
On the damBreak4phaseFine cases | paean | OpenFOAM Running, Solving & CFD | 0 | November 14, 2008 22:14 |
Could anybody help me see this error and give help | liugx212 | OpenFOAM Running, Solving & CFD | 3 | January 4, 2006 19:07 |
