Home > Forums > Software User Forums > Fidelity CFD
Pending solver tasks failing to start in FINE/Marine
Old   March 4, 2015, 12:25
Unhappy Pending solver tasks failing to start in FINE/Marine
Dan
dmuirhead is on a distinguished road
I am an undergraduate student working on a project using FINE/Marine.
I am having problems with the flow solver failing to start. No errors are thrown. After clicking the "play" button to start my simulation, the task manager window appears, a few lines appear and the last message is:
"start_status_ok"
Then nothing happens.
Switching to the task manager view, under Task List, the simulation's task status appears as "running" and under task delay it shows "none".
Under task definition, all three of pre-processing, solver, and post-processing are "pending".
My current problem set-up involves a simple, narrow hull geometry that was generated using Autodesk Inventor and imported into HEXPRESS as a parasoloid (.x_t) model. I meshed using C-Wizard, roughly following the steps of a FINE/Marine tutorial, making some modifications as appropriate for our hull, which is only 8m long. This is a steady computation, with the hull body motion defined as "imposed" at 4 m/s.
I believe I have ruled out an installation/licensing problem, as I was able to run a simple tutorial (Marine tutorial 1 - driven cavity, with geometry built entirely in the HEXPRESS editor) without any issue.
Can anyone shed some light on what might be causing this problem?
Thanks,
Dan
dmuirhead is offline   Reply With Quote
Old   March 4, 2015, 16:40
Romain
Rombzh is on a distinguished road
Are you using a Windows or Linux version ?
Rombzh is offline   Reply With Quote
Old   March 4, 2015, 18:02
Dan
Originally Posted by Rombzh View Post
It's Windows 7, 64 bit FINE/Marine version 3.1-3.
Old   March 5, 2015, 09:49
Romain
Well sorry I'm not familiar with the Windows version. In the task manager there should be a button called "save batch file" or something like that. It should create an executable that will run the preprocessing and the solver. Try running that job this way and see what happens.
I advise you contact Numeca's tech support.
Old   March 6, 2015, 03:29
Hamid Zoka
Hamidzoka is on a distinguished road
is that a parallel run?
I had the same problem in case of parallel run in Numeca.
Hamidzoka is offline   Reply With Quote
Old   March 6, 2015, 16:38
Dan
This is a serial run.
fine/marine, marine, solver
CFX 5.7.1 PRE and solver won't start daniel CFX 1 January 20, 2006 11:09
The solver start but stops immediately Anne CFX 11 May 20, 2004 13:23
compressible two phase flow in CFX4.4 youngan CFX 0 July 2, 2003 00:32
CFX 5.5 Roued CFX 1 October 2, 2001 17:49
Setting a B.C using UserFortran in 4.3 tokai CFX 10 July 17, 2001 17:25
