Home > Forums > Software User Forums > Fidelity CFD
Fine/Marine mesh improvement issue
Old   February 15, 2015, 23:39
Post Fine/Marine mesh improvement issue
anonymous
inarus is on a distinguished road
Hello all,
I'm working on a small project, and I'm not that familiar with all Numeca's functionality and tricks.
I've got this:
    SCRIPT FOR MESH QUALITY CHECK IN HEXPRESS
MESH QUALITY CHECK REPORT
>>> Domain: export_cf
> 2115936 cells
> Number of negative cells = 0
> Number of concave cells  = 0
> Number of twisted cells  = 0
--- ORTHOGONALITY ---
  Min     Max     Average    Standard deviation
12.80   90.00       80.13                  9.37
--- ASPECT RATIO ---
 1.00  438.01       14.71                 22.61
--- EXPANSION RATIO ---
 1.00   11.19        1.39                  0.39
> Computed quality color code: YELLOW
> Mesh quality is satisfying, but it could be improved
> Reason(s):
- Minimum Orthogonality: 12.80
-> Solution: increase Minimum Orthogonality to 15 degrees
- Maximum Expansion Ratio: 11.19
-> Solution: decrease Maximum Expansion Ratio to 5
     MESH QUALITY CHECK IS OVER
I studied the user manuals, and I can't find something related on how to fix the mesh.
Every issue propose a solution, therefore, my question would be, how to do it?
Thank you very much.
inarus is offline   Reply With Quote
Old   February 16, 2015, 09:03
Romain
Rombzh is on a distinguished road
Actually a minimum orthogonality of 12.8 deg is quite a good value already. As long as it is higher than 5 deg, no problem.
Rombzh is offline   Reply With Quote
sliding mesh problem in CFX Saima CFX 46 September 11, 2021 08:38
[snappyHexMesh] problems generating clean mesh Christian_tt OpenFOAM Meshing & Mesh Conversion 2 June 20, 2019 06:39
Issue with arbitrary Lagrangian-Eulerian method and mesh optimization mikolchon Main CFD Forum 0 August 16, 2014 16:50
Mesh motion with Translation & Rotation Doginal CFX 2 January 12, 2014 07:21
