Home > Forums > Software User Forums > Fidelity CFD
Fine/Marine parallel computation on multiple nodes
Old   February 15, 2015, 23:26
Post Fine/Marine parallel computation on multiple nodes
anonymous
inarus is on a distinguished road
Hi all,
To start simple, me and my Professor at school would like to run Fine/Marine on multiple nodes in a classroom, at first on 2 desktop PCs (Win7x64).
The main goal is to create a cluster from 5 + 1 servers (WinServer2008x64), located in an extremely noisy room, air conditioned, day and night, winter and summer. No IT professional in our University seems to have the time, interest or maybe the experience to help us out.
The servers are used mainly as license servers for various software our Professors are using remotely for research, CFD, FEA, etc, and sure, for a centralized intranet for our multiple classrooms and 2 separate buildings of offices including the towing tank facility.
I decided to ask here, and take some time to research how to achieve an MPI computation on at least some common i5 workstations.
Fine/Marine's license supports only 8 CPU's computing at once.
If we can achieve this, my Professor told would be a good opportunity to talk up further to extend the license for our need.
Thank you for your time.
inarus is offline   Reply With Quote
Old   February 24, 2015, 06:32
Maxime Petre
MaximePetre is on a distinguished road
Dear Inarus,
I confirm that it is possible to connect multiple machines to run FINE/Marine computations. The procedure is described in the FINE/Marine documentation. Did you have any trouble in particular? If it the case, the best solution would be to contact your Numeca office or agent to get support in your particular case.
Best regards,
Maxime PETRE,
Numeca International Support
MaximePetre is offline   Reply With Quote
Old   February 24, 2015, 08:38
anonymous
Originally Posted by MaximePetre View Post
Dear Inarus,
Best regards,
Maxime PETRE,
Mr. Maxime PETRE,
Thank you for your quick reply. I will look forward to the user manual. I suppose it will be very helpful.
If you don't mind, I will address further uncertain issues here.
Thank you very much!
numeca mpi
[ICEM] Assigning different number of nodes to parallel edges Rohit ANSYS Meshing & Geometry 3 September 22, 2017 10:16
simpleFoam parallel AndrewMortimer OpenFOAM Running, Solving & CFD 12 August 7, 2015 19:45
MPI code on multiple nodes, scalability and best practice t.teschner Hardware 0 October 7, 2014 06:07
Installation issues for parallel computation Akash C SU2 Installation 1 June 21, 2013 06:26
OpenFOAM static build on Cray XT5 asaijo OpenFOAM Installation 9 April 6, 2011 13:21
