Home > Forums > Software User Forums > Fidelity CFD
Multi-Species Simulation
Old   February 15, 2015, 19:24
Default Multi-Species Simulation
Richard Beauchamp
Richard Beauchamp is on a distinguished road
I have been trying recently to simulate the mixing of CO2 in air. To do that, I have created two blocks using Hexpress Hybrid, one containing each fluid. I also have put the proper fnmb conditions to insure that the flow through one block can get to the other.
Thus, I have an inlet of CO2 and an FNMB allowing the CO2 to enter the AIR domain.
Unfortunately, I am not able to see any mixing. I can see the speed gradiants caused by the CO2 entering the domain. Also, since the CO2 has a slightly higher temperature, I can see the temperature gradiants develop in the AIR domain.
However, when I try to map the evolution of the GAMMA parameter (Ratio of specific heats), it remains purely constant in the air domain.
I have seen that in the OUTPUT window, there is an option for multi-species output. However, I am unable to access it. It leads me to beleive that it is some type of flow model that I need to activate.
Unfortunately, I have not seen this obtion anywhere.
Can anybody tell me how to do a mixing simulation (multi-species simulation)?
This would be really appreciated.
Richard Beauchamp is offline   Reply With Quote
Old   February 16, 2015, 11:54
Erwann
tdrerwann is on a distinguished road
Hello Richard,
I would suggest that you have a look at the User manual, section 9-9 "Multi-species Framework" (and Theoritical manual section 8-8) + Section 3-2.7.
Also, it is not strictly necessary to create 2 blocks to run a multispecies simulation unless you need it for other reasons.
You could define one block with the boundary conditions defined by means of OpenLabs.
I hope this is useful.
Regards
tdrerwann is offline   Reply With Quote
Old   February 16, 2015, 22:20
Richard Beauchamp
First, I would like to thank you for helping. It is really appreciated.
Unfortunately, I am using a computer in my school's aerospace engineering department, and I have no idea where the user manual is. I have search extensively through the different folders of the computer and through the different servers available, but I am unable to find it.
Can you tell me just the basics of this section, I guess I can figure out the rest for myself.
Thank you again,
mixing gases, multi blocks, multi-species, multiphase
Species Mole and Mass Fraction Macro combustion FLUENT 18 February 5, 2024 13:23
Bubble plume simulation, multi phase flow Artvandelay Main CFD Forum 5 August 23, 2018 04:52
Boundary condition setting regarding turbine simulation using CFX Lacerlacer CFX 11 March 12, 2012 10:32
Problems about multi swirl tubes simulation using Jason FLUENT 4 May 9, 2008 01:33
CFD - Simulation of Condenser Multi void tubes Abdul Malique FLUENT 1 March 6, 2000 21:49
