Home > Forums > Software User Forums > Fidelity CFD
Adaptive Grid Refinement
Old   September 20, 2014, 10:55
Default Adaptive Grid Refinement
Lim Pei San
PeiSan is on a distinguished road
I facing problem to use adaptive grid refinement when restart from my previous computation for resistance simulation on my ship hull with SST k-omega model. In adaptive grid refinement, i set the flow solver as below for calm water resistance:
Criterion: free surface (directional) with no impose a minimum cell size.
Grid quality: set 2 full criterion copy layers and 0 fraction layers. In addition, using longitudinal refinement in the boundary layer.
Box: i make the box using the criteria directional refinement only
Control: i use 25 time steps and number of partition is 1000000
In hexpress, i just make a standard mesh without putting a refinement box for the whole hull.
However, the computation keep fail with the reason job aborted and stopped by all blocks. Is it my setting on making the box cause the problem? Anyone has suggestion on these problems?
Thanks
PeiSan is offline   Reply With Quote
Old   September 26, 2014, 05:46
Francesco
Francesco1951 is on a distinguished road
Hi!!!
I have the same problem!
When I activate the grid refinement the simulation crashes!
Francesco1951 is offline   Reply With Quote
Old   September 26, 2014, 06:11
Lim Pei San
Hi Francesco,
I think you need to do the local refinement in hexpress which draw the refinement box under adaptive section there then only can do the adaptive grid refinement. You may try it. Hope you succeed it.
Old   December 16, 2014, 10:04
Gijsbert Struyk
gijsbertstruyk is on a distinguished road
Hi, I have exactly the same issue as Francesco:
Simulation crashes when AGR kicks in...
Tried in serial and parallel, both crash.
My setting are similar to PeiSan:
Criterion: FS directional with a certain target, no min size limit
Grid quality: set 1 full criterion copy layers and 1 fraction layers. In addition, using longitudinal refinement in the boundary layer.
Box: I make a box for all refinements around the ship, longer downstream
Control: I use 10 time steps and number of cells per partition is 500000
Advanced: I check: "base FS on smoothened mass fraction" and "Limit scalar product..."
Anyone found a solution to this?
gijsbertstruyk is offline   Reply With Quote
killed "snappyHexMesh" parkh32 OpenFOAM Pre-Processing 2 April 8, 2012 18:12
Adaptive mesh refinement in two-phase flow (Wigley Hull) jantheron OpenFOAM 6 October 7, 2011 13:59
[snappyHexMesh] snappyHexMesh aborting Tobi OpenFOAM Meshing & Mesh Conversion 0 November 10, 2010 04:23
Adaptive Mesh Refinement and Cyclic Boundary Conditions adona058 OpenFOAM Running, Solving & CFD 6 October 23, 2009 10:17
Grid Independent Solution Chuck Leakeas Main CFD Forum 2 May 26, 2000 12:18
