Home > Forums > Software User Forums > Fidelity CFD
Viscous resistance and Pressure resistance
Old   September 9, 2014, 12:37
Default Viscous resistance and Pressure resistance
Lim Pei San
PeiSan is on a distinguished road
Hi everyone,
May i know what is the standard proportion for viscous resistance and pressure resistance in calculate total resistance? As i read one of the journal about resistance simulation for trimaran, it stated that the pressure resistance is below 30% of total resistance. However, in the result data produced from my project about catamaran, the viscous resistance and the pressure resistance are nearly the same. Any suggestion or idea about this problem? Your help will be appreciated.
Thanks
PeiSan is offline   Reply With Quote
Old   September 10, 2014, 09:24
Romain
Rombzh is on a distinguished road
It really depends on the kind of boat/shape you're dealing with, Froude number, if it's a displacement mode / semi displacement / planing...
It's not because you read it should be 30% and that you do not have this, that what you did is wrong.
Rombzh is offline   Reply With Quote
Old   September 22, 2014, 04:35
Lim Pei San
Rombzh actually i have already consist the information of the experimental data which i just run the simulation according to the information provided in it. Unfortunately, the pressure resistance still higher than the viscous resistance where suppose the viscous resistance is higher than pressure resistance. Now, i really dont know where i suppose to change in flow setting to get the correct answer. Any suggestion about it?
Thanks
Inertial Resistance and Viscous Resistance Data ravitejakatragadda FLUENT 5 May 10, 2018 05:16
how to calculate the viscous and inertial resistance coefficients? omurakbayir FLUENT 1 November 22, 2010 23:36
resistance & pressure losses Jan CFX 0 May 14, 2002 08:33
what the result is negatif pressure at inlet chong chee nan FLUENT 0 December 29, 2001 06:13
How to obtain correct viscous pressure drag using CFX? Ketut Utama Main CFD Forum 1 January 25, 1999 06:05
