Home > Forums > Software User Forums > Fidelity CFD
Resistance Simulation for High Speed Hull in Turbulence to Match Experimental Data
Old   September 3, 2014, 01:08
Default Resistance Simulation for High Speed Hull in Turbulence to Match Experimental Data
Lim Pei San
PeiSan is on a distinguished road
How i am doing resistance simulation with turbulence model. I am sure that fine marine is a dedicate software to simulate the resistance, but my result still have around 50% error in getting accurate answer. I am sure there is some mistake i made in setting procedure but i dont know where is the problem that cause the result came out inaccurate. Any suggestions to make an ideal or standard setting for resistance simulation in turbulence model for high speed which used to compare with experimental result?
PeiSan is offline   Reply With Quote
Comparison the airfoil 0012 experimental result and simulation result harrislcy FLUENT 30 August 29, 2013 11:27
Experimental results do not match with simulation results robingilbert OpenFOAM Verification & Validation 4 January 23, 2012 18:39
Experimental And Simulation Data for my model Timothy Song Siemens 0 January 12, 2009 06:23
Natural convection - Inlet boundary condition max91 CFX 1 July 29, 2008 21:28
PhD in turbulence Hans Main CFD Forum 14 October 8, 2001 04:03
