January 7, 2014, 08:10 |
Hexpress: Refinement Box definition
Tim Franke
Rep Power: 17 |
defining a refinement box in the domain by clicking two corner points on the screen is in some occasions not very convenient when you want to have your box at a specific location. Are there alternative ways for definition by typing the coordinates of the two corner points? Or even better import an stl-file that defines the refinement region? Regards, Tim |
January 16, 2014, 11:18 |
Colinda
Rep Power: 14 |
Dear Tim,
When you have selected to create a new box, you can left-click in the section at the bottom (just below the black bar) that indicates: Enter >> With the cursor in this line you can then type the x y and z coordinates separated by a blank space and confirmed by pressing Enter. Then you can type the coordinates of the second point in the same way. Alternatively you could write a tiny macro containing the command: create_refinement_cube(x1, y1, z1, x2, y2, z2) but probably through the GUI on the Enter line is easiest. |
[snappyHexMesh] Adding layers goes wrong with SnappyHexMesh | Elise | OpenFOAM Meshing & Mesh Conversion | 1 | April 22, 2013 03:32 |
[snappyHexMesh] snappyHexMesh refinement regions ignored | guitarbren | OpenFOAM Meshing & Mesh Conversion | 2 | April 9, 2013 04:59 |
killed "snappyHexMesh" | parkh32 | OpenFOAM Pre-Processing | 2 | April 8, 2012 18:12 |
OpenFOAM static build on Cray XT5 | asaijo | OpenFOAM Installation | 9 | April 6, 2011 13:21 |
[snappyHexMesh] snappyHexMesh aborting | Tobi | OpenFOAM Meshing & Mesh Conversion | 0 | November 10, 2010 04:23 |
