Home > Forums > Software User Forums > Fidelity CFD
Emergency Request
Old   December 12, 2013, 03:52
Default Emergency Request (Multi prossecor)
Ali T is on a distinguished road
Dear all friends
How can we run NUMECA fine\turbo in parallel computing? (For CFD and Optimization!)
I have NUMECA fine\turbo 8.9.1.
__________
Best Wishes
Ali T is offline   Reply With Quote
Old   January 16, 2014, 11:42
Colinda
colinda1 is on a distinguished road
You can easily define a parallel computation through the TaskManager (accessible through the Modules menu of FINE/Turbo). You can define, launch and monitor your parallel computation directly from the TaskManager or alternatively you can use the TaskManager to prepare the files needed to launch in batch.
colinda1 is offline   Reply With Quote
Old   January 23, 2014, 10:43
Deneriaz Alphonse
alederiaz is on a distinguished road
Is it possible to create a more balanced partition between all the processors or we can only allocate numbers of blocks to each processor?
Thank you
alederiaz is offline   Reply With Quote
Old   January 23, 2014, 10:53
Colinda
Sure, in FINE/Turbo v9 you can use parallel partitioning to have a better balance over all the processors.
In the Task Manager simply select on the Tasks definition page: "Parallel Partitioned Computation"
Old   January 29, 2014, 07:30
Deneriaz Alphonse
Should I select 'parallel computation' after starting the solver?
If I want to do it before I can lot select the computation from the list. If i do it later it do not use all slave processor selected
Probably I missed a step.
Thank you
Old   February 6, 2014, 04:38
Colinda
In the FINE TaskManager you should first select the *.run file of your computation. Then select "Parallel Computation" and modify the "Parallel Settings" all before starting the solver.
Mesquite - Adaptive mesh refinement / coarsening? philippose OpenFOAM Running, Solving & CFD 94 January 27, 2016 10:40
[OpenFOAM] Saving ParaFoam views and case sail ParaView 9 November 25, 2011 16:46
Problem with paraFoam ata OpenFOAM 14 November 30, 2009 05:23
Installation OF1.5-dev ttdtud OpenFOAM Installation 46 May 5, 2009 03:32
[OpenFOAM] Xwindows crash with paraview save srinath ParaView 1 October 15, 2008 10:37
