Home > Forums > Software User Forums > Fidelity CFD
Vertical Axis Wind Turbine
Old   November 7, 2013, 08:17
Default Vertical Axis Wind Turbine
Fabio Gigante
f.gig is on a distinguished road
Dear all,
I need your help to do a 2D structured mesh for Vertical Axis Wind Turbine
using IGG(NUMECA grid generator).
Is there someone with experience on vertical axis? Which is the best way to do this mesh?
I'm trying to make a three blade mesh with tower in the middle. Do you have an example of configuration of this structured mesh?
Thanks in advance
f.gig is offline   Reply With Quote
Old   December 6, 2013, 04:31
CJ
oldshoes81 is on a distinguished road
Send a message via MSN to oldshoes81 Send a message via Skype™ to oldshoes81
It would be best if you could find your local support or you may contact NUMECA directly.
Regards
CJ
NUMIT Enterprise, Malaysia
+6 017 656 3436
http://maccom-numit.blogspot.com
http://www.numit.com.my
Email : seiko.q@numit.com.my
oldshoes81 is offline   Reply With Quote
Old   December 11, 2013, 14:37
Fabio Gigante
OK, thanks.
Old   May 4, 2014, 09:39
Joan Ali
Joan Ali is on a distinguished road
how should it be for
Joan Ali is offline   Reply With Quote
Old   May 30, 2014, 10:57
Fabio Gigante
Hi guys,
after a lot of tests I managed to generate the mesh I wished. I made a 2D mesh with 3 airfoils NACA0015 and tower using NUMECA grid generator. I made just a section of 120 degrees and I have rotate twice this section to have a complete turbine domain.
Now, I'm trying to setup the simulation using NUMECA solver but I'm having some problems. Is there anyone can help me?
From NUMECA manuals and tutorials I did not find any example for vertical axis wind turbine. The main problem is to setup the mesh rotation, because I want to rotate the entire domain.
Another doubt was the mesh properties, because if I select cylindrical coordinates, I can choose only between 3D and Axisymmetric. But my mesh is not 3D, so I'm not sure if Axisymmetric is the correct way.
Any help will be appreciate.
Thanks a lot
structured mesh, vawt
Vertical Axis Wind Turbine atorninc Main CFD Forum 3 March 6, 2013 05:38
Vertical axis wind turbine DrBidden FloEFD, FloWorks & FloTHERM 4 December 21, 2012 21:50
Vertical Axis Wind Turbine Rotating Domain Problems TWaung CFX 4 May 1, 2012 04:14
Reversed flow in Vertical axis wind turbine Anonymized_JL1 FLUENT 2 April 11, 2012 04:13
Vertical axis wind turbine in NUMECA ArslanOZCAN Fidelity CFD 2 July 21, 2011 06:04
