Home > Forums > Software User Forums > Fidelity CFD
guidance for correcting results for a variable geomerty radial turbine.
Old   March 17, 2013, 17:35
Default guidance for correcting results for a variable geomerty radial turbine.
Priya
Priya is on a distinguished road
I am working on a variable geometry radial turbine in numeca and i need some help to let me know if the results are correct are not,I will be posting them soon if needed, Or it would also be nice to know about what should be expected.
The Radial turbine is tested with a speed range of 90 - 130 krpm with a varying hub clearance of 2%- 4% 6%8% and 10% of 7mm.
I do understand as to what could the consequences in a theoretical point of view but i do not understand what to expect from the results seen in the software.
Any suggestions or reading material would be very helpful.
Thank You
Priya is offline   Reply With Quote
Convergence of Radial Turbine Simulation Hugh CFX 10 June 30, 2010 09:08
radial turbine flow analysis ME CFX 6 July 11, 2007 23:47
radial turbine flow analysis. ME Main CFD Forum 0 July 1, 2007 10:39
CFX application to radial inflow gas turbine Chetan Mistry CFX 5 June 2, 2007 14:13
radial turbine data export question ally CFX 0 September 14, 2005 16:10
