July 12, 2012, 10:13 |
Import Exisiting Meshes into NUMECA
Zoe Burton
Rep Power: 15 |
I'm currently simulating steam turbine exhaust diffusers and am looking to use NUMECA to run a calculation of a LP stage and accompanying exhaust hood. The CAD models have been developed in Solidworks and meshes generated in Pointwise and previous calculations run successfully in ANSYS Fluent 12. I am now looking at using the extended capabilities of NUMECA, but am unsure how to import my existing meshes from Pointwise (which were many weeks in devleopment!) to run in FINE/Turbo. Any help would be greatly appreciated. Kind regards, Zoe |
July 13, 2012, 13:26 |
Zoe Burton
Rep Power: 15 |
I solved this problem - the mesh I was trying to important has unstructured blocks in the tip region and I am now in the process of remeshing in AutoGrid5.
I developed an FEM toolkit in Java: FuturEye | nkliuyueming | Main CFD Forum | 7 | January 29, 2016 14:28 |
Import transient cfx-results for static structural analysis in Ansys WB 13 | Colt Seavers | ANSYS | 1 | August 11, 2011 07:01 |
[Other] Import or generating Meshes from Koordinates Gau%c3%9fKr%c3%bcger | toby | OpenFOAM Meshing & Mesh Conversion | 7 | February 27, 2009 16:25 |
Errors running allwmake in OpenFOAM141dev with WM_COMPILE_OPTION%3ddebug | unoder | OpenFOAM Installation | 11 | January 30, 2008 21:30 |
[Technical] File format for import meshes in OpenFoam | t42 | OpenFOAM Meshing & Mesh Conversion | 5 | August 1, 2007 09:45 |
